Go Back   3dmm.com > 3D Movie Maker > 3DMM Chat
Old 05-29-2024, 03:59 PM   #1
Jamieisidiotic
Issue with custom Actor
I had learned each and every step there is to making a custom actor for 3DMM. It worked, or, so I had thought. The actor works, but there is an issue with it. Whenever I move it one direction in scene mode (or whatever it's called), the model itself will point in a different direction. For example, if I move it right, the model points forward. If anybody knows how to fix this, please tell me!
Jamieisidiotic is offline   Reply With Quote
Old 05-29-2024, 04:03 PM   #2
Libya
Rotate the model in the correct direction.
Old 05-29-2024, 04:08 PM   #3
Jamieisidiotic
Re:Issue with custom Actor
Do you mean in Misfit Model 3D or 3DMM? Because I previously tried both, and neither worked. The model still pointed forward when going right, backward when left, right when forward, and left when backward.
Old 05-29-2024, 04:37 PM   #4
Libya
Do it either way.
Old 05-29-2024, 04:42 PM   #5
Jamieisidiotic
I had tried that previously, and it didn't work.
Powered by vBulletin
Copyright ©2000 - 2025, Jelsoft Enterprises Ltd.
